xer1,
Any luck with the vacuum leak testing? Try this method for leak testing if you find nothing with the car in park with engine in idle and at varying rpm i.e. 2000-3000 rpm.
The next test will require a helper you can communicate well with. We'll test for 2 things:
--Ignition misfire under load,
---Vacuum leaks.
First Ignition misfire.
With engine
OFF, one at a time, pull each plug wire out of the distributor tower and then set the wire back in the SAME tower
with out snapping it in so that all six wires can be lifted out of their respective towers one at a time and set back in with out using much force to do so. Next, with an assistant sitting in the vehicle with parking brake fully engaged and
wheels chocked ,place the transmission in drive and, working from the sides so you don't get squished if your helper forgets for a second, he has your life in his hands
, try to obtain the rpms where the misfire occurs. If the misfire can be replicated pull the wires out one at a time USING INSULATED SPARK PLUG PLIERS, OR ANY WELL INSULATED TOOL THAT WILL GRASP THE WIRE AND GIVE YOU GOOD CONTROL OF IT, and look/listen for the cylinder that has
NO effect on the engine performance and/or RPM. Theory: If a cylinder is cutting out, regardless of the cause (ignition, fuel, air leak, compression) when that cylinder is taken out of the firing order by removing the wire from the tower, there will be NO noticeable change in the performance of the engine (thus identifying the non-firing cylinder that is causing the misfire in the first place) and giving us a solid place to focus on. Even with a misfiring engine, there will always be cylinders which are firing properly or the vehicle would not run at all. Have your helper watch the tach while doing this test and note the rpm drop in each cylinder, to see how much of a contribution each cylinder is making to the performance of the engine and which one (if any) contributes less than the others or nothing at all.
When you've finished this, shut off and reattach plug wires securely then restart and using same method as prior, go around looking for air leaks and paying attention to any noticeable change in performance/rpm increase.
You'll want to be REAL thorough, and go over things 2-3 times and at the risk of not reiterating enough--BE CAREFUL NOT TO SPRAY ON ANY ELECTRICAL SOLENOID, SWITCH OR CONNECTOR (I always have a fire extinguisher close when doing this).
Also, I forgot to mention, as almost every engine function on your vehicle is controlled by the control monitor, I advise you to get your hands on a decent scan tool-one that gives out real time LIVE ENGINE DATA. Amazon has an Innova Equus 3130
scan tool for around a hundred and a half that is a third of the manufacture site. I saw it for a hundred on Ebay yesterday (new) w/ free shipping.
I think you'll hit on the problem if you take a methodical, consistent approach focusing on locating the cause, as opposed to jumping around trying to hit on what will "fix" it.
Happy hunting.
I'll be interested to learn what is causing the problem.
Have a great weekend.
