QX4ME »
https://forums.nicoclub.com/qx4me-u5464.html
Mon Dec 22, 2003 8:39 am
I don't know where the "propellar shaft" lubrication point is. Just a guess: When I look at the rear axle from back of the truck, I see two screw type of pluges, one facing back, the other basically facing down. Are those for propellar shaft lubrication? QX4 maintenance log says the recommended grease is NLGI No.2 (Molybdenum disulphide lithium soap based). Is it critical? If I don't use Infiniti's service but some other independent service shops who apply other type of grease, will that be bad?
Thanks.
