QX4 - LSD. . . how do I know?
KoukiS14
Car: 2005 Infiniti G35x
Lakeshore Slate / Stone
Hey!! I feel good finally being able to post in here. I just bought a 99.5 QX4. I know the options sometimes grouped the lsd with heated seats and sunroof, and I have both of those. I *think* I have a vlsd, but how can I tell?
I did search, but I couldn't find nothin'
Thanks!
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
post up the VIN and i can tell you what options you have...
KoukiS14
whoa that'd be sweet I'm glad to be back on here. .I wasn't so active with my 240sx.
Anyway. .
Thanks!!
JNRAR07Y1XW061693
elwesso
2007 BMW M Coupe
Were you the guy located in Anderson?? just wondering...
As far as your options, the parts book brings up stupid stuff, like different sunvisors and a larger battery....
apparently the H233B came in an LSD and a 2 pinion (open) diff on the JR50... You could NOT get the LSD with 2wd, but it was optional for 4wd....
If your QX4 has the "premium sport" package, it will have the LSD... Along with this package comes power operated tinted glass sunroof with tilt feature, heated front seats (requires sunroof).. So if you have both of them, you PROBABLY have the LSD, since it was really the only option you could get...
Worst case scenario, you can get under the car, look at the rear diff, and it will have a sticker on it somewhere that says "LSD".
KoukiS14
Yeah that was the only option I could find. I have heated seats and a sunroof, and I don't know if those could be ordered ala carte or not. The packages for other Nissan and Infiniti vehicles doesn't seem to be as screwed up as it was for my 240sx.
I'll go under and check anyway. . the 240 will have a sticker too. . I should've known.
Thanks!!!
edit: I'm in Lafayette
KoukiS14
I'll throw this in here because I'm sure it's been posted -- but I couldn't find anything during a search.
When do I need to change the timing belt? I've only ever had timing chains before.
Thanks
elwesso
2007 BMW M Coupe
Yours has the VG33E... no timing belt!!
KoukiS14
It sucks starting over from scratch and having to learn all the nuances of a new vehicle after driving 240s for 7 years. . haha
I thought the VG had a timing belt while the VQ had a chain?
elwesso
2007 BMW M Coupe
the twin cam VG did, but not the single cam!
chaonis
It has timing belt. Service manual suggests having it replaced at 105K miles.
Modified by chaonis at 9:58 AM 11/3/2006
KoukiS14
chaonis wrote:It has timing belt. Service manual suggests having it replaced at 105K miles.
Modified by chaonis at 8:30 AM 11/3/2006
:o yeah I found somethin bout it here: http://www.infinitihelp.com/In...r.htm
elwesso
2007 BMW M Coupe
Hmm, i was referencing the 03 QX FSM (which I stupidly assumed was the same).... Sorry for the misinformation!!!!!!
KoukiS14
elwesso wrote:Hmm, i was referencing the 03 QX FSM (which I stupidly assumed was the same).... Sorry for the misinformation!!!!!!
haha that's alright sir I WISH I had a VQ.
KoukiS14
Nope. . no LSD :o oh well. . .
rubiconxj
Car: 2001 QX4, 1980 280ZX 10th Anniversary
elwesso wrote:Worst case scenario, you can get under the car, look at the rear diff, and it will have a sticker on it somewhere that says "LSD".
You could also jackup the rear end. Spin the tires, if they go in the opposite direction it is an open rear end...no LSD
KoukiS14
rubiconxj wrote:You could also jackup the rear end. Spin the tires, if they go in the opposite direction it is an open rear end...no LSD
I just mashed the brake pedal and throttled it up in a wet parking lot, and observed the lack of spinnage from left rear tire.
Interesting, because my new whip has all options but that. It was packaged, as was said, with sunroof, heated seats, etc. . maybe those could be purchased ala carte like in the 240sx?
Still learning all there is to know about the R50
angusangus
Car: pathfinder
learned this the hard way-almost all 01-up qx4 has lsd but it is a viscous type vs. clutch type on older models i.e. with viscous it's very mild unlike older models with very positive locking action
nissandoms47
Car: 2002 Nissan Pathfinder SEV6-Custom 7" lift-33-1250R15 BFG KM2- a bunch of other s*** i cant think of
just to answer some questions i saw when i skim read this.
VG33Es have t-beltsVQ35DEs have t-chainsEvery 4x4 QX4 that i know of came with an LSD rear and 4.6 gearing. dunno about vlsd tho.
angusangus
Car: pathfinder
yes,yes and no99.5-up qx and pathy have 4.363 gears,99-under-under has 4.636and yes the viscous lsd will spin only one tire on pavement , wet or dry sometimes,really only locs up on snow/ice or dirt/mud.Why did they do this?maybe b/c 3.5 has more power and they didnt want old ladies/soccer moms to drift through corners!?well anyways i bought 4.363 96' pathfinder pumpkin,gonna swap it in and go drifting!!!
nissandoms47
well i learned something new. thats kinda stupid they didnt use the 4.6s in the VQ powered r50s. my 96 is an XE and it came with 4.3s, i plan to upgrade someday. i just put the sliders on! woot
angusangus
Car: pathfinder
nissandoms47 wrote:well i learned something new. thats kinda stupid they didnt use the 4.6s in the VQ powered r50s. my 96 is an XE and it came with 4.3s, i plan to upgrade someday. i just put the sliders on! woot
is yours manual trans?
nissandoms47
nope, i would hate an MT for offroad.
fueler
Car: 2 Nissan's
2 BMW's
angusangus wrote:yes,yes and no99.5-up qx and pathy have 4.363 gears,99-under-under has 4.636and yes the viscous lsd will spin only one tire on pavement , wet or dry sometimes,really only locs up on snow/ice or dirt/mud.Why did they do this?maybe b/c 3.5 has more power and they didnt want old ladies/soccer moms to drift through corners!?well anyways i bought 4.363 96' pathfinder pumpkin,gonna swap it in and go drifting!!!
I have a QX4 manufactured in 4/99 with the 4.636 gearing from the factory..... LSD diffs will have an orange sticker on the pumpkin.
to check, take off e-brake, chock front wheels, lift rear wheels off the ground and spin one. if the other spins opposite, NO LSD. If the other wheel spins same way, then you got LSD.
angusangus
Car: pathfinder
fueler wrote: I have a QX4 manufactured in 4/99 with the 4.636 gearing from the factory..... LSD diffs will have an orange sticker on the pumpkin.
if you have vlsd it will seem like a non lsd when you jack it up and try to rotate wheel,and im pretty sure if your production date was 6/99 it would be 4.363
nissandoms47
im sure they put the 4.3s on when they started with the VQs. so lets just stick with that.
angusangus
Car: pathfinder
ya i guess yhats the easy way to put it ! should have thought of that , apparently there were both ratios with the vg,but only 4.36 with vq!anyways, anyone else notice that their vq has ****ty lsd?
