ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.html
Tue Aug 23, 2011 7:37 am
As Densetsu has indicated the transmission with used oil although it may look clean has many contaminants within it and these particles get into the small passages of solenoids and clog and stick the action of the valves.
Changing the fluid every other year is a very good preventative. Remember the transmission loads up the engine and a 1-2-3-4 gear change loads the engine further but when within the speed range the gear range will equal what the ECM is expecting, but if a valve sticks no matter what the ECM says for the proper gear and range the electric signals go unheard.
It's like trying to start off in third instead of first with a manual, you and your brain soon realize there is a problem and you re-shift to 1st. Your built in wiring corrects the situation, but what if the shifter is broken and physically stuck in 3rd, your brain knows what to do but can't tell your body to do it because of a mechanical issue beyond the brain's control.
You can save a lot of grief, money and time with simple PM, this is a PM that should be done, it will save diagnosing a complex issue with a complex transmission. An oil change out is not complex, a bit dirty and will offer you insight into that box behind the motor via the feel, smell and look of the oil and the particles that come out with the oil.
Auto transmissions have clutches, bands, solenoids, small oil passages that rely on proper pressures and action of a liquid to hydraulically do a job. That oil does a lot but it does it when the oil is dirty or clean, but the dirty oil changes and these changes affect the way thing operate. With very close tolerances dirt is not wanted or needed. Viscosity changes and cleanliness is critical inside any hydraulic component be it:
transmissions
Brakes
Clutches
ABS
everything hydraulic
