DalCarpone »
https://forums.nicoclub.com/dalcarpone-u134047.html
Fri Aug 28, 2015 2:42 am
I have changed all of my bulbs on the face plate I went from the white to a medium blue, I am no electric wizzard !! Take out your Head unit and make yourself a clean area to work as this may take some time..Just look over how everything comes apart take a few pictures... If you are just going bulbs unsolder the bulb at the base, once base is off clean up area on circut board be very very careful !!! replace with same size 12v lamp . Now for the fun part, Put a very small half drop of super glue in the middle of the base, apply to circut board now put a very tiny pin head sized solder on the bulb wire to circut board.. Job Done ! Put back together take your time ..
Now if you really want a fun job do all of this with LEDS you will need two different kinds BUT THIS IS ANOTHER STORY !
