I am quite new to this nice forum. I own a 2003 QX4 and it is a WONDERFUL car.. I bought it brand new from the dealer and it just passed the 100,000 km mark, so you can say i use it lightly as i have another car. I live in Saudi Arabia. Frankly speaking, I used to take the car to the dealer shop regularly for inspection, but I stopped that for quite some time now.
Lately, I started noticing that the engine temp is increasing gradually until it reaches almost to the H mark. To be honest, I started to notice this 'abnormal' increase in temp before winter season. But during winter the engine temp was very low, especially that I did not operate the AC for almost 3 months. However, as I started to operate the AC these days, the temp problem came back again.
About 3 years ago, I had a similar problem, but to less extent, so I took the car to the dealer shop. They replaced the radiator, thermostat, fan clutch and belts and every thing was great (aside from the $2.5k that I had to pay
This time, I decided to take the car to a nearby shop, but I was really shocked when the mechanic told me that the problem is in the engine!!.. He claims that there is an internal leakage in the cylinder head and he must open the engine. He also claims that the radiator and thermostat are OK. Although I am not a mechanic but I thought that if what he says is true, then I should lose the water in the radiator, which is not happening.
I believe that the problem lies in the thermostat or water pump. Last night, I ran the engine with the AC on for quite some time until the temp reached barely above the C mark (ambient temp was 65). The radiator cap was open and I could NOT see any clear flow of water through the radiator cap hole. Any advise? Many thanks in advance..
Khalid
