ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.html
Tue Apr 12, 2011 12:46 pm
After you got the engine stated go home and test the electrics. Do it at home because when you find the problem you are in a safe place to fix the problem.
There is no room for error, thus there is no room for a wiggle of any connection to make things work.
To start: Verify the battery is being fully charged. A full charge by the alternator leaves the battery at 12.6 minimum voltage. Any lower you have a problem. The battery will range from 12.6 to 15 V depending where it is in charging.
All cables need to be secure, tight and CLEAN, all cables. All joints also, all ground connections via bolts need to be loosened cleaned then tightened and verified 0 ohms resistance to ground.
Once the battery connections are verified then the alternator must be checked at all RPMs. Then the combined efforts of the battery and alternator with the various loads in the car.
No assumptions, do a check of all systems
