Densetsu »
https://forums.nicoclub.com/densetsu-u91979.html
Mon Nov 30, 2009 7:31 am
Quick check to see if you have LSD:
1. Lift both rear wheels off the ground.2. Turn one rear wheel by hand.
If the other wheel turns the same direction simultaneously, then you have LSD.
(Yes, stolen almost word-for-word from the FSM)
Or just do what alex said, buy LSD gear oil and use it. LSD gear oil is fine in non-LSD diffs (but not the other way around!)
