qx4 climate control buttons do not light up
redoctober
Car: 2003 Infiniti QX4
i have a very annoying problem. the last 3 buttons on the right side of my climate controls do not light up in my qx4. i think the LED in that area probably burned out or something. so I was wondering how difficult would something like this be to replace. i guess i need to find a detailed diagram of how to remove the plastic piece on the dash to get the climate control out. then i need to figure out how to pop off the front cover of the climate control to get to the LED. has anyone done this before? is this difficult/time consuming? where did you find the instructions and technical drawings on how to do it. I also need to find the part number of the LED that I need to replace. does anyone know where I can find it?
thank you in advance for your help. i much appreciate it. james
timmack
Car: 2002 Nissan Pathfinder SE
ever consider trying to track down a complete used unit from a salvage yard or ebay? might save you the headache of pulling the unit apart and having to buy and replace the one little led, thats assuming they are replaceable.
SnowSurfLax
Car: 1999.5 Infiniti QX4
2006 Infiniti M35 Sport
I don't believe the part is very hard to replace, but it does require pulling the dash. That's gotta be one of the worst parts of vehicle work for me, I hate pulling dashes.
I believe you can find the part for cheap, around $150-200 through one of the sponsors. Someone else may have to chip in on which one. Our rigs aren't always so easy to find in a salvage yard, but if you're intent on keeping it cheap and don't mind waiting, that's the way to go.
