qx4 bottoming out
epicsurge
Car: Infiniti QX4 99.5
my qx4 starts bottoming out whenever theres 1+ people in the rear, checked under and the bump stops are all rusted out, the struts are rusted too.
Is it both or also the springs? will post pic tomm
miamiheat3332
Car: 2002 Nissan Pathfinder SE - 2006 BMW X5 4.8is - 2001 Audi A4 1.8T Quattro Sport
Rear isnt struts, they are shocks.
How many miles are you your Q?
Your looking at least to get new rear coils, bump stops, and shocks. Depending on mileage, you might as well replace the struts and springs up front while you have it apart.
If your looking for a bandaid or cheap fix. Get new shocks, and put airlift 1000 in the rear coils. But i would do it right versus bandaiding the problem.
epicsurge
96k miles
BoostMyQX4
Car: 96 Infiniti QX4
Speaking of Shocks, i need to change mines.
What is a good brand shocks to get?
The springs i have no clue where to get them from, as well as the Bumpers that go inside the prings.
miamiheat3332
KYB Gas-a-just is the best ones, and they arent expensive either.
Shop around for best price.
BoostMyQX4
Kool
Pathofinder
Car: 2001 Nissan Pathfinder 2wd Vq35De
Airlift1000 kit will make it ride great again and never bottom out
Take out your old bumpstops and be sure to run a schrader valve to each bag to make slight psi tweaks
It will hold up that sagging rear end and never allow it to bottom out, wold probably raise it up a bit in the rear to
Costs $100 and installed with a simple floor jack, 2 drill bits and no specialty tools
miamiheat3332
Advance Auto has it for $88 if i recall, use coupon code VISA 30 off 75, and you get airlift 1000 for 58+tax.
Or to end up with a sweeter deal, buy something extra for $12, and find the 40 off 100 coupon code, i forgot it off the top of my head.
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
miamiheat3332 wrote:and find the 40 off 100 coupon code, i forgot it off the top of my head.
CCABIN
BoostMyQX4
So there is no need to replace the shocks? or replace the shocks as well if you install the lift kit?
miamiheat3332
No you should replace your shocks, but the airlift is a bandaid for the bottoming out coils.
BoostMyQX4
miamiheat3332 wrote:No you should replace your shocks, but the airlift is a bandaid for the bottoming out coils.
Got-Cha
