I've done the same research.
Seems like you want the same thing I want, so here are your two choices in order of my preference:
1) Hankook Ventus ST RH06 2) Toyo Proxes S/T
Here are your choices on where to buy.Hankook:1)
http://www.1010tires.com/tire....+RH06
265/60R17 at $134.99 a piece. There is a shipping cost. (if that link doesn't work, just search for Hankook Tires on
http://www.1010tires.com)
2)
http://customwheelsmarket.com/....html 275/60VR17 at $108.00 a piece. FREE SHIPPING. THIS IS WHAT I WOULD BUY!
Note, 265/60R17 is near exact of 245/65/R17. But given prices and choices, I would definitely get the $108 a piece 275/60/R17. I promise you won't have any rubbing or any issues. I have a friend with 31" tires and he has no rubbing (revo's). Also, his speedo is actually MORE accurate now, he has a gps unit that tells his speed.
Toyo Proxes:1) Only buy them from ebay. They are really cheap.
http://cgi.ebay.com/ebaymotors...%3AIT
or search for item number: 7955250479 275/60R17They are $96.99 a tire +shipping.
Buy the Hankook Ventus ST RH06 275/60/R17. They're the cheapest, same specs as Toyo Proxes (420 AA) and both have outstanding reviews.
Hankook Ventus ST RH06 are also m/s rated, so you can go through occasional snow, but these are really wet/dry tires, so don't expect much.
I have bridgestone dueler h/p, or whatever is OEM on the 01 QX4. They are pretty bad in about any kind of weather, so Hankook Ventus ST RH06 would definitley be better than that. Can you believe the wear rating on OEM tires are 180??
Email me if you have any more questions.
