skinnyphatman »
https://forums.nicoclub.com/skinnyphatman-u33024.html
Wed Sep 28, 2005 1:48 pm
I purchased a 1999 QX 4 earlier this year with about 95K miles on it. I took it in to have the timing belt chanted (105K service) and it turned out I needed some additoinal work, pretty expensive. I needed to have the breaks re-done, and bearings re-packed along with the timing and other belts. In addition to that, they recomended that I do an induction flush to clean the fuel injectors and flush the transmission. The shop said I could probably wait a little on the last two and since the other items totaled a nice sum, I deferred the indiction flush and the transmission flush.
Now, time to pay the piper... I am interested to see if either or both of those services are something I could do myself. I am pretty handy and with the right tools and good directions, I am confident with most anything (short of major engine work).
The induction flush appears to be more than a quart of STP or other additive in the tank. I saw a show on DIY where they did a flush and it appeard pretty simple with the right stuff (although it was on a Tarus). Basically disable the fuel pump, hook up canister of solvent through a pressure regulator, appropreately set, to the port bewteen the pump and fuel rail (sort of like a tire stem, used to check fuel pressure, etc.). Run the engine on the solvent until it is gone... Re-engage the fuel pump and viola! Done. It can't be that easy, can it?
Now, I will probably have the transmission flush done at the shop, as I probably lack the tools, although I did see a method of flushing by emptying and filling with new transmission fluid a few times until things get a little cleaner. I gotta think that a professional job is better... Right? Also, and I am sure this is bugus, but when I had the vehicle inspected the inspector said the transmission fluid looked OK, but was starting to get a little dirty. But he also said, that some advise against a transmission flush beyond 100K miles. Is that true? false? debatable? wives tale?
I look forward to putting many, many more miles on my QX4. I am happy to have found this place... I guess it really is true, you can find anything on the internet these days. Thanks for any help you can provide.
