DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Fri Jul 29, 2005 5:35 pm
Sorry, can't post much this weekend as I am totally swamped literally 12 hours/day. I really don't know the answer to that. Aside from the riding just a tiny bit higher, I would *guess* it's probably OK. If the lower flange on the strut starts to bend then you'll know there isn't enough area to take the load, but again I think it's fine. This is another reason I DIY at home--if I screw up the alignment I can tweak it right there. I can't keep the isolators in the same spot and turn the spring while on the car.
