quickest way to pull cams at junkyard
centralcoaster33
Car: 1997 Nissan 240SX #5
I scored on finding a wrecked 94 dohc s13 coupe and want those cams for my s14. What's the super fast removal steps and tools needed. Thanks. Yeah, I could go step by step with my FSM, but if it can be quick let me know. Also, it was an automatic... Do you think it'll have the vlsd?
H.D.HUMPERDINK
Car: '92 240sx
take a pry bar and break the timing chain. then, unbolt the caps and that the cams home.
Brandon93240
Car: 1993 240sx
U can just pull the valve cover and all the caps, lift the cam(s) out from the back towards the front and it will let the chain drop down. U don't need to try breaking the chain, what a f$cking idiot.
LayNLow240
Car: 92 240 coupe
yeah, all you really need is a 10mm and some type of cutters for the chain if it becomes a problem.
WI_S14_Goldie
Car: 1995 Nissan 240sx SE, 91 240 fastback LE, 1997 kouki S14, DD = 93 Nissan Maxima
tools: 10mm, 27mm, torque wrench, big monkey wrench...takin them out the regular way isn't too bad...and time consuming..
dsc4130
H.D.HUMPERDINK wrote:take a pry bar and break the timing chain. then, unbolt the caps and that the cams home.
thats a bad idea, i see cams snapping in the near future
LayNLow240
Car: 92 240 coupe
WI_S14_Goldie wrote:tools: 10mm, 27mm, torque wrench, big monkey wrench...takin them out the regular way isn't too bad...and time consuming..
27mm? for what? theres no way your getting the cam gears off at the jy without compressed air. just cut the chain and pull them out.
Gramentz
Car: s14
You could do it with another wrench holding the cam in place while you turn the 27mm....couldn't you?
Philsnotfalling
Car: 90 hatch 93 coupe
dude if u take all the cam caps off u can lift both cams out from the back to the front and the chain will slide off the gears, its that easy, I guess no one read the 3rd post or something.
scruffy63
Car: my nissan 240sx
LayNLow240 wrote:27mm? for what? theres no way your getting the cam gears off at the jy without compressed air. just cut the chain and pull them out.
You my friend are a sad excuse for a male. Anything can be done without air tools. But I suppose if you have no muscles, air tools would be a must have. can you take off all of your wheels one after the other? just playin. well for my single, if I remember correctly, I had to put a bar or something in one of the holes on the cam gear so it wouldn't move while unbolting it... not sure if that would work on a de. but its an idea.
LayNLow240
Car: 92 240 coupe
i was actually afraid of rounding off the spot for the wrench on the cam itself.its also a little weird pulling on one wrench and pushing on the other.
Shift_Kouki
Car: 95 Nissan 240SX SE
I ussed a 10mm and a set of bolt cutters when I pulled some altima cams last summer.
Not to be critical... but who the hell uses the timing chain over again out of a motor that is not working, and that you are allowed to pull cams from?? If that motor is ever gonna fire again... It will be due to a complete rebuild, and oh yeah they need cams now that youre done too. Why would I waste two seconds of my time trying to save that used chain instead of using bolt cutters?... again, sorry if that sounded like a rant, but that is what i have learned from my local parts yards.
Also, take the valve cover too if it is still there. They make good holders for the cams untill you put them in. Plus then you have a spare to get painted / powdercoated if you ever feel the need to do that in your car's engine bay.
Brandon93240
Car: 1993 240sx
it takes longer to cut the chain than it does to lift the cams out from the back to front. U don't have to do absoultely anything to the chain to get them out. U still have to take all the cam caps off to get the cams out in the fist place either way u do it, why worry about cutting something when its not needed.
centralcoaster33
Stupid internet! It went down for like four days. I was wondering why no one responded to my post. Then I look today and there's a ton of tips and even some flaming entertainment. I must have forgot to subscribe to the thread or something. Thanks so much for all your help guys. I'll go back there with the sockets. I'll bring a prybar and bolt cutter, just in case the chain doesn't fall off easily!
Florida240sx
Big wrench think 15/16??? big soxket 1/2" with 27mm socket.. Undo rod caps and your good. Although someone said you can tilt it to the front so no need to loosen anything but the rod caps...
