quick z32 front brake question
project_240le
Car: 1991 nissan 240sx le
I am considering a z32 26mm front brake upgrade on my 1990 240sx, does anybody know if these rotors/calipers will fit in my stock 12-hole 15 inch aluminum rims? Also, if i get the brakes from the scrap yard, will i need any special adaptors for the brake lines to connect? i searched.thanks
dan222000
Car: 1996 Nissan 240SX w/SR20DET
I believe they will bolt right up. I have the same upgrade on my S14 with my stock SE wheels they fit fine. Now I upgraded my wheels and I had to use a 10mm spacer to clear the caliper. So I guess it depends on your wheels.
bikerskater
Car: 1990 240sx with s13 front end
i have them on mine and let me tell you unless your planing on auto-x a lot or sr or something bigger of engine soon its not worth it for the trouble you have to go through with rims and what not
Hijacker
Car: '92 240sx Convertible
'94 F-150
You didn't search at all. This is the most covered topic in the history of NICOdom.
http://www.nicoclub.com/articles.php?id=207414
All the information you want on Z brakes is right under your nose. We don't hide it.
You will need conversion lines as Z brakes use a flared fitting to hold the line to the brake whereas 240s use a banjo bolt.
