Quick wheel quesion
NickWendt03
Car: 95 240
I have an s14 zenki with tein s-tech lowering springs. Im pending a buy with wheels that are 18x8.5 all around with a +33mm offset i know they will fit in the rear but will they in the front? Ive tried searching just couldnt find an exact answer
SILVIAJayS
Car: 1996 Nissan 240SX SE
Yes. Front will be close to the strut, just watch your tire size. I ran a 225/45 with no problem.
simmode1
Car: Red '95 S14
Those are the same specs as Z33 rear anniversary wheels. I have a full set of four mounted at all 4 corners with 225/40/18's with no problems at all. Lowered on Eibach Pro's.
You'll be fine.
NickWendt03
Car: 95 240
thanks for the input, yea im running 4 rear 350z track rays wheels. Im also now buying 235/35/18 wheels.
tramp_drift240
Car: 1992 240sx SE Coupe
235/35/18 tires.
and those have got to be expensive as hell, ive only found two companies to make that size and they arent cheap. at all.
why dont you bump up to a 235 40 or a 245 since youre in an s14.
SILVIAJayS
I had the exact same drop and wheels on my S14, and I wanted bigger tires to fill the fender, so I do not recommend the 35 series.
