I was forced to fabricate a bracket for my wastegate actuator which would place the wastegate against the block. It's literally being pressed upon but with not much force at all. Ive pressure tested this wastegate and it works perfectly in it's position but I figure I would ask here. Are there any rubber seals or anything I should have to worry about when heat is applied to this part?
Thanks!
