Zinister »
https://forums.nicoclub.com/zinister-u50298.html
Thu Nov 09, 2006 8:58 am
They have re-circ. valves on both sides on the plumbing between the intercooler and the TB. Basically its the "blow-off valve, but it just recirulates the air bacl into th intake stream. Aftermarket BOV's for z32s are a waste in my opion. If you do decide to go that route, make sure you get some kind with a recirc system because the car was designed for that extra air, so it will run funny without it. You will experience rough idle issues if you just vent to atmosphere. Its just for the "cool" noise at this point. The only need to get BOV's would be for insane HP numbers. I do think HKS makes a recirc aftermarket BOV system though.
