Quick Update for the NICO ECU guys!
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Alright, we are almost ready to start actually reprogramming the ECU's. Everyone who has sent an ECU AND HAS PAID should be golden.
IMPORTANT: WE ARE CURRENTLY OUT OF 94-95 ECU EQUIPMENT. We have 5 people who sent us ECUs and I have 5 cores, therefore we have no more 94-95 ECU's available and one of the cores does not get reprogrammed.
Therefore, I will no longer be accepting payments for 94-95 ECUs OR 90-93 4 ways. THEY ARE GONE, WE ARE OUT OF BOARDS TO REPROGRAM THEM WITH.
However, we still have plenty of 90-93 2 way switch boards, so you arent SOL. IF you want an ECU, you can either wait on a core (I think im going to have 2 or 3)...
I think pretty much everyone that wanted one is in now, so we should be fine!
db_autotek
Car: 1994 Q45t black & 1993 Miata racer. Previous: 1994 Q45, 1992 Q45.
Awesome!!!! I'm excited!! Hope I got the payment to ya in time (this morning)
elwesso
2007 BMW M Coupe
Yep you got in JUST BARELY but you are golden!
Q45tech
Will you guys burn a single program 91+ octane PROM so I can finally get around to comparing your program to my 14 year old Dinan Chip?
Talk about late to the party?
elwesso
2007 BMW M Coupe
Tech I will have a few spare ones if you want to try one, if you want to buy one we have the 2 ways, for stage II and stage II...
If you wanted to just try it, I can send you one of my ECU's once I get them and you can dink with it as long as you want.
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
I am going to remove my NICO ECU for a while, and want you to modify it with several programs.
Any chance I can get it done?
elwesso
2007 BMW M Coupe
Jeff, we dont have any more hardware for multi-programs... We only have 90-93 ECU 2 ways.
Q45tech
I don't want to take a ecu out of circulation from a member as I can just swap the chips.
Better base line in using the same ecu and just changing WOT program......my trusty stopwatch.
ILuvNkdChx
Car: Q45t, I30t
Wes, do you know if Robert has recieved my ECU yet? I sent it out mid-week and just wanted to make sure everything was going smooth.
ScottJackson
Car: 91 Q45, 92 Q45a, 93 Q45, 79 BMW 635CSi, 95 BMW 540i
Hey Wes, I realized I still have that ECU that came with Chopp's car I bought. I also have a '93 ECU. I'm very short on cash right now, but how much would it cost to have the '93 ECU set up for Stage 2 and a boost program? I've kinda been away from the board a while (finishing up school and working hard on the farm). If it'd help bring the cost down, I could donate a '91 ECU and maybe some brackets for my 13" front ford Cobra rotors conversion (if/when I actually get around to making them). The 2-way setup will work for these two programs, right? Would the boost program be a basic one that just richens up the fuel under load and takes out some timing at the same time (based on load)? If so, how well would that work with 550CC injectors and everything else being stock? I don't think I'll be going above 10-12psi of boost.
Modified by ScottJackson at 1:02 AM 5/28/2007
elwesso
2007 BMW M Coupe
Q45tech wrote:I don't want to take a ecu out of circulation from a member as I can just swap the chips.
I asked Robert, I'll let you know.
Adam, without double checking ym emails im 99% sure we got it and youre all set.
Scott... If its an early style ECU its $200 for the 2 way...
The boost program is a very basic that just adds fuel and has less timing. Its very experimental and basically is only to be used as a starter program, which you would then tune yourself or have someone tune for you. This will not work well with bigger injectors as youd want to make a new program for 555cc injectors.
