Quick transmission question
motoxris
Car: 92 240sx coupe
Sorry I'm at work and didn't want to search.I just needed to know if the s13 single cam and dual cam transmissions will interchange. I thought the bell housings might be different or something like that. Thanks guys
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Searching would have said yep they are the same
biggie
Assuming 5 speed manual, yes the same. AT is a different story.
motoxris
Car: 92 240sx coupe
Yeah. I do have a 5 speed.
biggie
motoxris wrote:Yeah. I do have a 5 speed.
Then 89-98 5speed will work in the S13 without issue.
motoxris
Car: 92 240sx coupe
I called a wrecking yard for a transmission and they said they don't interchange. Why would there program say that?
xX RB Xx
Car: SE3P, FC3S, FC3C.
^ because they are retarded.
FS5W71C is the transmission in 240s, 84-89 NA 300zx, SR20s and RB20s. To use an SR transmissons, just change the bellhousing.
To use the 300zx FS5W71C, swap the front and rear cases. This works vise-versa
To use the RB20 transmissson, Im not sure.
All cars that use the FS5W71C have the exact same internals.
biggie
motoxris wrote:I called a wrecking yard for a transmission and they said they don't interchange. Why would there program say that?
They are trying to keep things simple. There are some small differences (like the speed sensor), but they are the same. On 95-98 transmission using on a S13 you would want to swap the speed sensor and probably plug the CAS hole at the top of the bellhousing near the engine.
But for the 89-90 vs 91-93 5spd they are the same except for the speed sensor.
