Quick timing question
theother1wstolen
Car: 92 240sx Coupe SE
My timing at idle is usally at 20bdtc but it does drop to 9 - 10, and when i rev the car up almost to red line it goes all the way to almost 50, is this normal or is my knock sensor shot? (data was logged with obd scantool)
bruinbear714
theother1wstolen wrote:My timing at idle is usally at 20bdtc but it does drop to 9 - 10, and when i rev the car up almost to red line it goes all the way to almost 50, is this normal or is my knock sensor shot? (data was logged with obd scantool)
If your ECU is stock and your mechanical timing is at 20 deg, what's the issue?
theother1wstolen
trying to figure out why i have a lack of low end power.
theother1wstolen
almost forgot, it also runs rich in the lower rpms and lean in the higher rpms, normal or no?
theother1wstolen
-bump- anyone?
