quick timing question
hatch-attack
Car: 1990 240sx Hb
Ok I found a 94 altima 5spd with 137k on the mtor. It has the typical empty spray can sound under the timing cover. I know I just need to remove the 2 upper timing guides and clean the tenioner to get rid of this noise. My question is the car is located 1hr away from where I live. Will I be able to drive it home without having to worry about destroying the motor?
ZOOMIGUEL
Car: 1989 240sx SR20DET
2006 Lexus IS250 AWD
is your engine shaking?
it could be your distributor,unscrew both screws , dont pull dis. out, turn on car, move distributor left or right, you will see difference of car shaking, timing...
my distributor is moved all the way right, runs perfect.. then shut off car and screw em back on ... perfect
dickie
Car: Killer Turtle
your problem could be much bigger than a dirty or clogged tensioner. look into replacing the chains, tensioner and guides or risk bent valves.
