quick timing question need answer soon!
jt15833
Car: 95' 240SX
doing my HG, i have the upper timing cover off and am doing the belt. If i align the crank pulley to 2nd from the left mark, and the cams appropriately, and there are 39 cogs between cam marks, its correct ya?
i can not count the teeth between exhaust mark and crank, so i hope this is sufficient.
Thanks
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
Just make sure all the marks are lined up. If it runs like crap, re-do it.
trevr
Car: '07 Mitsubishi Eclipse V6 swapped supercharged
'93 Nissan 240SX Vert CA18det **SOLD**
I suggest to turn the crank by hand before you start it with the ignition. This is the safest way to be sure you are not in interference. Use a large socket on the crank bolt and turn it a few times.
bentvalves
Car: 89 Silvia K's
yep dont bother counting cogs on belt, just put it at TDC, and align marks on cam gears, and timing cover mount plate.
and yea I always like to turn the motor over by hand plugs out after a rebuild or timing belt job rather than fire it up right away.
when building oil pressure for the first time after a rebuild or a swap, take your sparkplugs out btw....maybe relevent or may not be, good practice regardless.
r34 gtr
Yeah, always turn it over a few times by hand to make sure everything is okay, then pull the coil main plug or the fuel pump fuse and turn it over a few times and make sure the timing hasn't changed. Sometimes (most of the time) there is slack in there that comes out after a few quick turns and the gears become a tooth off.
psilocyben
Car: 1992 240sx
Yeah 39. This may be way over kill but just for your own info look at this
http://www.driftopia.com/2008/...y-way/
