GringoEJS »
https://forums.nicoclub.com/gringoejs-u26601.html
Sun Apr 24, 2005 7:32 pm
OK...first of all, I have searched and searched and get partial answers. Surely someone here can give me a quick answer. I replaced the headgasket, and ended up needing to pull off the front cover. I replaced everything, but think my timing is off. Anyway, my questions are: 1) Of the 6 notches on the crank pulley, is TDC (0 degrees) represented by the 2nd notch from left to right? 2) My cam pulley has a small circle, like a reference point. It is now at 9 o'clock, which I think is wrong. Where should it be (more or less) After replacing a timing tensioner and headgasket, the car just turns over. I thought I had the chain on correctly, but I now doubt it since I have compression, spark, and fuel. I didn't line up the reference links while the cover was off, and I hope that someone can just tell me where that dot on the cam pulley is supposed to be.
