nukeone »
https://forums.nicoclub.com/nukeone-u31978.html
Thu Aug 25, 2005 9:27 am
Just make sure you properly fill and vent when re-installing and please exercise caution when opening the vent valve/nut Since the vent valve is on the return side back to the radiator, you may not actually get the piping completely filled until the car warms and the thermostat opens. So, I always fill it, let it run with the vent cracked, and then add water/coolant to the reservoir as needed until completely filled, and then close the vent.
