Quick TDC compression stroke question
rudee023
Car: '03 Infiniti Q45
When setting the No.1 cylinder to TDC on its compression stroke, would the cam lobes both be facing inward or outward. I have been trying to look to see when the both sets of valves are closed but I'm retarded. Thanks in advance
180fan
Car: 89 fastback
the knock pin for the exhaust cam should point upwards.
the knock pin for the intake cam should point out to 11 o'clock or so
