thanks alot... the "pushing in the wheel" part really help.. i was trying to push the hole red part until i read this...adrians_s13 wrote:really?
lol...
loosen them with an allen key, then push the wheel in the desired direction. If you get to a point where the nut is against the strut tower, remove them and put them into one of the other holes. Make sure you don't forget to tighten them.
Also, those tick marks are for you're own knowing. They don't really tell camber degree, for that you'll need to go get an alignment or get some kind of compass and measure it yourself.
i moved it to the point where the nut is against the strut tower.. and dont wanna camber it anymore... can i leave it like that?adrians_s13 wrote:really?
lol...
