*Quick Steering Wheel Question*
(Q)240
Car: 92 240sx s13 Coupe
i did some searching but found nothing about my question..ok so ima get a new aftermarket steering wheel soon. probably a nardi... and i was reading about how alot of times people dont get their horn to work after they install an new steering wheel / wheel hub...
im have an 92 s13 and was wondering what steering wheel hub and quick release would garuantee me a working horn and no other starnge problems like turn signals staying on after a turn...
thanks in adavance
maj Andres
Car: Zenki, '95 Model, w/ S14SR20DET
I think it should be an easy swap and your horn should work with out doing any modifications. Unlike the S14, since it came with air bags and complicates things. Stay away from circuit sports hubs, I currently have one and is stuck!
(Q)240
maj Andres wrote:I think it should be an easy swap and your horn should work with out doing any modifications. Unlike the S14, since it came with air bags and complicates things. Stay away from circuit sports hubs, I currently have one and is stuck!
yea thats what i was thinking cause i read the s14 was the harder one cause it had airbags... but ive heard other complications with the turn sugnals not auto stoping after turning..
Flicktitty
Car: 1989 Nissan 240sx 2JZ-GTE Swapped
1994 Toyota Supra
2019 Lexus GX460
1992 Lexus SC400
i have a HKB hub on my s13 and the blinker doesn't shut off
(Q)240
Flicktitty wrote:i have a HKB hub on my s13 and the blinker doesn't shut off
does that happen cause of the way u set up the plugs or cause the hub it self is like that?
inertiaprojectCC
Car: 1993 240SX
I have a MOMO steering wheel and MOMO hub in my '93. Everything bolted up perfectly, my horn works and the signal lights turn off every time. Only issue was I had to drill out the holes in the steering just half way so the set screws fit flush instead of sticking out (just personal preference I think it looks cleaner).
Cone Junky
Car: S13 fastback
BMW e46 328i
I also have a Momo/Momo setup and everything works perfect.
(Q)240
thanks for the answers.. anyone got a nardi with NRG setup that has everything working?
N2mesnob
Car: 95' SE Pathfinder
Don't know how relevant this still is but i came cross this thread thought you might wanna check it out: zerothread/278253
