Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Wed Feb 11, 2004 2:25 pm
1: i personally use 10w30 on my car, and being in woodbridge, your climate isn't much different from mine, so you might wanna consider that weight.
EDIT: Make sure you use synthetic oil. It takes longer to break down due to the heat.
2: Oil feed line tighten to 14-23 lb ft, Oil return line - 9-12 lb ft. water feed tube - 14-23 lb ft, water return - 14-23 lb ft.
3: that can you're talking about is an oil catch tank. Leave it on. You can take the breather hose off, but make sure you put a small filter over it.
