Quick sleepy eye question
s13importuner7
Car: 1991 240sx
i just did the sleepy eye mod. but lets say last night i wanted them up but then this morning i wanted them sleepy. do i have to go through all that crap again adjusting them. is there a way to avoid all that. btw i did the lit sleepy eye (thanks vroom-chirp)
1. Press the head light motor control button in, Notice nothing happens now, it's because you cut the brown wire, good.
2. Turn the lights on with your stem switch on the steering council, the head lights should now open, turn them off, Notice they don’t go down, again the brown wire, good.
3. Using the headlight motor control button, lower the head lights to the desired position by pressing the button in and out, this can be tricky since the lids go down once you depress the button, and they stop once you press it in.NOTE: if you close them all the way, repeat steps 1 and 2 again.
4. Once you finally get it where you want them, turn your new switch to the off position, and the turn your head light on with the stem switch again.
5. Get out and marvel at your new lit sleepy eye look.If your driving with your sleepy eyes lit and you notice its getting dark, just turn you switch to the “on” position and the head lights come all the way up and on.
95silvia14
Car: 1995 240SX, 1993 s13 coupe
yes you have to do the steps all over again but to be honest what it takes all of 10 secs if you have to do it more than once
