motoman399 wrote:hey can you briefly explain how you made the pressure pot? i have never seen how one works, and i have a spare tank laying around. thanks and i would go with a fine grit walnut shell, but i have no experience with walnut shells, just heard good stuff about them.
i just got a bag of crushed glass and walnut shells yesterday, just finished running the copper piping in the garage, needs a few drain valves and the air dryer and water seperator hooked up and i should be good to go.heres a quick write up of what i did, you can do whatever way u want tho.
its actually very easy, this is pretty basic. I'm terrible at explaining things, but i'll try.
Short version - Weld a 2" nipple or bigger in the top. Weld a 3/4" nipple in the bottom, look at the pic
what i did - i cut the top off the tank a few inches down, then cut a 2" hole in the centre, ( just drilled a hole and used a die grinder stone to get the right size), welded in a 2" nipple, welded on both sides of the cut off top. there are alot of better ways to make the filler port but i chose this because i had the material laying around. If doing this way i would recommend at least a 3" nipple. (in case something falls inside, gets plugged etc. You can get your hand in there (you could probably get away with just cutting a hole for the nipple, I removed the whole top because i was planning on doing it another way)
-On the bottom, i welded in a 3/4" nipple
-Now you need some way to get air into the tank. Threre were a few threaded holes already in my tank from the compressor, but you could drill a hole and weld on a nut, just make sure everything is air tight. Mine was about 6" from the top. I had another nut beside it i used for a pressure gauge, and one on the opposite side i used for a release valve, the release valve was leaking and snapped when i tightened it, the drill bit snapped while drilling it out, so there was a bunch of s*** in there and i couldn't get my hand in to get it out because of the 2" top nipple, thats one reason i recommmend at least a 3"
Then start running the pipe. I just picked up a lenth of 3/8" pipe from a plumbing wholesaler , i ordered a pipe threading kit a while back that works great. So I could just thread all the nipples i needed. (no one in my area ever has what im looking for, if you can get what you need from a shop/store it might be easier for you)
-I threaded a 3/8"x1" nipple and screwed into the tank (side of tank, near the top)-then thread a Tee To the other end of the nipple-Another 3/8" nipple threaded to the opposite side of T-Thread a Ball Valve to the 3/8" nipple-Thread a Male Quick Connect, into the ball valve (for air hose to connect)
You can use whatever size pipe, fittings, valves, etc. May require reducers, to connect pipe to valves etc.
The bottom of the tank, the 3/4" nipple was welded in earlier - I threaded a gate valve on the nipple.. My gate valve was 3/4" but you could use whatever size ya want .-now I need a reducer to connect the gate valve to the rest of the piping, i used a 3/4" male to 3/8" female Reducer-attached 3/8" nipple to the reducer-the other end of the nipple attached to a T-Okay now one side of the T Is going to be where you hook up your hose for blasting(I used a nipple, ball valve, and a hose connector. Then used a 6 foot piece of old rubber compressor hose.)
-The other side of the T (on bottom) needs to meet the piece coming down from the T (top) By the upper ball valve (look at pic)Take some measurements, remember to leave room for threads, i think 1/2" each side will do. I put a 1/2" union on, saves alot of hassle if it needs to be disconnected.
Once its all finished, fill it up with air, and check for leaks. I put 125psi in mine and had water in a spray bottle. If you find a leak just grind the part of the weld that was leaking and lay a bead.
I used a stick welder with 3/32 6011 rods, but any welder you have will work
-The air goes in the tank, and down the pipe to the valve by the hose, so there is pressure to move the sand to the gate valve then when you want to blast open the ball valve by the rubber hose and blast away.
hopefully that makes sense, i've never used or even seen a sand blaster before, just went off a pic, i'll take few pics of the nozzle/gun i made and explain that, i ordered 2 ceramic nozzles from princess auto, one was 1/8, the other was 3/32. im late for easter dinner with the family tho. do that later
Modified by KYZAAC at 6:22 PM 4/4/2010
