SirSilvia wrote:note: i have H4 conversions so these are pics of those bulbs
Are you talking sealed beams? either way this is the pinout and its not a single element in the sealed beam either since its all about the angle. If you notice when you hit the high beams the beam is actually aiming higher off the ground then the low beam. If it only provided more power to the single element they'd call them bright beams.
Modified by SirSilvia at 9:04 PM 1/1/2010
yeah i noticed that afterwards, i was just fooling around with it and a 14 v battery last night
i got it wired so that it flips on correctly but i got no high beams, which is fine with me because what i did was:
took the 240sx bulb housing and cut it and stuck in a lexus high beam projector and bulb and right now im fabbing the eye lid so that it will pivot when i want the eyes to close and open because its pretty big projector
its really bright, anyways yea making clearence for it has been the biggest thing but its getting there, ill post when its all done and legit
