s13drifter88 wrote:yes it is possible to install it. you'll have to have both the axles tho. the r200 uses a longer axle on one side where the r230 uses 2 same length axles. the 230 i believe is also a clutch type (IIRC) and the others are all a vlsd
You will need more than axles to put an R230 diff in your S13. Much more challenging then finding axles will be finding a way to bolt in the diff. It is physically larger (wider) than the R200 and the mounting ears dont line up with the S13 subframe. (I'm curious if a TT subframe would bolt into a Z32NA. That would be the only time I'd try a R200 to R230 conversion on a S13, S14, or Z32. Then you add the hassle of HICAS.) The Z32TT R230 is a VLSD.
puerkone wrote:I see. well I guess the only way to find out is buying both differentials and compare them. I just found out that if I want to use another r200 or r230 differential, I also have to change the wheel bearings because the s13 hubs use 29 spline wheel bearings and the z32 twint turbo use 30 spline hubs. so I guess one way to start is to buy the 30 spline wheel bearings that way I can just buy the axels from a q45 or z32 and will line up with my hubs. I will post some pix as soon as I start buying stuff hehe. But I will definately try the g35 differential because it is the same rear bolt pattern from an automatic car. I will get the axels too since they are 30 spline I just checked.
Measure them before you start throwing money at diffs. Not even sure which two diffs youre talking about, but doing your homework will save you plenty of hassles and dough. I think youre off to a get start.
You'll learn that you cant just bolt in a R230 diff, and neither the S14 or J30 diffs and axles need TT hubs. You only need the TT hubs if youre using the G50 diff. If using the G50 diff, you will need one axle from the G50 and one from a Z32TT. You will also need the TT hubs. I'm willing to bet G50 hubs will work but have not read/seen this before.
I dont know squat about the newer G35/Z33 setups cause I like cheaper, older parts. The G35 axles might be 30 spline, but you also need to verify the length is correct.
Other stuff:
Nissan diffs have 3 types of output shafts: 6 bolts evenly spaced (Q45, Z32TT), 5 bots evenly spaced (some J30's and all? Z32NA), and 2x3 bolts (all? US s13/S14 and some J30).
I dont know why you'd try swapping the axle ends. If you must you a G35 diff, that may be an option (custom axles I mean. I wouldnt try swapping ends). Or maybe some combo of Z32TT, G50, and G35 axles will work.
I'm quite sure the G50 R200 has a 200mm ring inside. Not sure how the unit could be interchangeable with other R200's if it had a 230mm ring inside. And I'm nearly positive the S13/G50 rear covers are interchangeable and allow the G50 diff to fit into an S13.
The J30 diff does have a 3.916 gear.
I just read your links. I'm beginning to suspect the G35/Z33 diff is very similar to the G50/Y33 diffs. I have not been able to compare G50 vs Y33, and have not touched a G35/Y33 diff. Also that parts list in the first link explains which G50 and Z32TT axle you need and where to install them. That article lists pretty much everything you need to know, though I didnt recall that a S14 rear cover must be swapped to put in a Q45 diff. And G50 hubs should work.
