crappys13 »
https://forums.nicoclub.com/crappys13-u38123.html
Fri Jun 02, 2006 9:50 pm
4 PT Roll cage...Ok, i have one, i just went outside to take pics but it was to dark. It will fit however i would advise you make it a 6pt rearsection. What i did was get an autopower main hoop, request it half an inch narrower, it should cost about 70 bucks for the main hoop. Figure out if you want a diaganol bar and harness bar. I got both. Weld that togetehr with the plate s on the bottom. The rear section. .. ok waht i did here was make an x-brace from the top to the side of the wheel well to eliminate as much flex without adding tons of weight. then you cut two holse to gdet the bars to access the shock tower in the rear. Bring them from the main hoop straight back to the shock towers. then weld the plates and weld them in. cost me 250 bucks total and i welded it myself.
If you have questions, try to PM Me
