mtcookson »
https://forums.nicoclub.com/mtcookson-u3042.html
Fri Feb 08, 2008 6:18 am
I'd definitely get a timing light on there. If you advance it too much you will actually lose some power. I think generally you shouldn't advance base timing more than 3°.
I'd also hook up a wideband o2 if you can and consider getting Nistune or similar to tune it as, generally, NA cars tend to make a bit more power with a leaner mixture.
