doainwpg »
https://forums.nicoclub.com/doainwpg-u13984.html
Wed Dec 15, 2004 2:49 pm
that looks like the stock one i took out a month ago. make sure you get the right clutch to go with your flywheel, sohc & dohc had different flywheels/cluctches. basically if you have an SOHC flywheel you need the SOHC clutch. however the SOHC flywheel bolts onto a DOHC and vicea versa
