Quick release Steering Wheel
vstone48
Car: 1979 Pontiac Trans Am (Sold), 1990 Nissan 300zx, 2005 Chevrolet Silverado 1500 (Totaled)
Ricer in the house guys, so i just bought a Momo steering wheel, and nrg hub and quick release and was wondering if anyone can tell me how to remove the stock wheel. I havnt tried anything yet becasue i just ordered the stuff but i went and looked around my car and just saw 4 screws underneath the wheel. So are those the only things i have to remove in order to strat taking the plastic off to get to the hidden stuff? I did do some searching on google, NICO, and twinturbo.net and found this to be the most helpful
http://answers.yahoo.com/question/index ... 539AABKfIG
So is what the last guy says it? becasue i looked to the left of the wheel and didnt see anything...maybe i need to get my eyes checked? Thanks in advance
A Paratroopers 300zx
Car: 1992 Nissan 300zx Twin Turbo
2004 Toyota MR-S
First off, do you have an airbag? If so, it will be a lot more complicated and not legal.
*DISCLAIMER* It is illegal and unsafe to remove the airbag system as per federal regulations, unless the car is intended for track use only. Also, disconnect the battery BEFORE starting the job and if you aren't mechanically inclined... Do not attempt.
That being said... if no airbag: remove the 4 screws that hold the steering column trim together. Located on the underside of the trims pieces. Then, look/feel around for screws on the back of the steering wheel itself that holds the face plate onto the wheel. Remove face plate and locate the center nut holding the wheel onto the column spline. Should be a big nut... something like 19mm if memory serves. Remove nut and give the wheel a solid tug... will be pressed on with a bit of force.
If airbag: Same thing as above with the careful exception of removing the airbag assembly within the face plate. It requires a special set of 3/8 bits known as a security/tamper proof bit set. Also, with the installation of a new wheel... it will disable the horn and turn signal return function. When you go around a corner, the turn signal will not automatically click back off. Easy fix to both of those... horns can pass safety inspections with a different horn button mounted within reach of the driver. Turn signal can be manually clicked off... just have to remember to do so :bigthumb:
Hope that helps! Which Momo wheel did you go with?
vstone48
no im pretty sure i dont have an airbag because i got a 1990 and there is no srs airbag logo on the wheel and thank you very much that was exactly what i was looking for thanks so much. I freakin love this forum.
