Take it off how? It looks like the sensor + plug were crimped on with some type of brass fitting. I have the PVC Tape, that's not a problem, I just didn't see how to take it off without damaging anything in the limited amount of space i've got.Sil240 wrote:Take it off, put some plumbing tape on it then re tighten it. Replug it in.
getting a closer shot now. It is attached to the oil sending unit.KUILLIN_DRIFTER wrote:get a closer shot! that is not the average oil pressure sensor. got a strap wrench?
WTF? 12 or 14 metric wrench? Care to circle which part would come off with a 12 or 14 mm wrench?KUILLIN_DRIFTER wrote:ok that is the stock sending unit. I think i took it off with a 14 or 12 metric wrench. You should see some wrench flat edges to take it off(look at the bottom where it mates to the oil cooler unit). Strange place to leak. Normally doesn't happen. get it off and let me know hell you can call me if your interested!
You mean behind this red part?KUILLIN_DRIFTER wrote:
its under the circled red part that you have illustrated
it's sending it out where the plug is usually plugged into. Any parts or part #s so I can get a different sending unit?fast_s14 wrote:if it is leaking from under neath the blue part, you will have to replace the sending unit.
I'll have to put it up on jackstands next chance I get to remove the old one. Anyone have a good part # I can use instead so I can go ahead and get it ordered and added of my list of things to do while she's up on jackstands?Carl H wrote:looks like some one replace the stock sending unit with a ka sensor, while this isnt bad they might have crossthreaded it and that is causing the leak...it could also be a bad aftermarket part from the get go.best bet is to pull it out and replace it with a brand new switch from nissan.
So is this the part I need to pick up at autozone/oreillys?drifter92sx wrote:yea thats wat i did wit my rb20 swap cuz i didnt want to wire up the oil pressure sensor yet but the ka oil sensor will work and the threads r the samejust remember to wrap around the threads the plumbers tape for good sealing and wont have problems with it leaking latr
yes but you need to run a 1/8 bspt die on your autometer sender to cut it down so it will thread into therejohnny butt wrote:
"Ka Oil Pressure Sensor?"
Either way, if that's what that sensor does, I have an Autometer gauge I have been meaning to hook up and get a sensor for anyway. Will me doing that solve the problem?
no, my hydraulic jack broke the one time I needed to use it so I've got to take it back and get another,KUILLIN_DRIFTER wrote:did you get it off yet or what? lol!!!
thanks, let me know! here or via e-mail (i also e-mailed you. )Coolwhip wrote:yea as mentioned before, looks like a cross threaded KA sensor in there if it's leaking.
Brad, i'll check exactly what size is for everything under that as I have both sensors and housings laying around.
This looks like the unit on my car now. Cross-referenced to a KA24DE Sender (Probably kept for the dummy light for the gauge cluster.)gawdzilla wrote:yes but you need to run a 1/8 bspt die on your autometer sender to cut it down so it will thread into there
