RB25/RB26 Water pump will NOT work on RB20.
Let me find my old post and quote it here...edit:
zerothread?id=226242
The slot will expose the water passageway underneath and you will not be able to get the pump to seal. In that drawing, the pink line shows the water passageway, the yellow is the slot outline and the light blue is where you'll see the leak. The gap that is created by the slot is bigger than can be safely sealed with RTV.
Sell that pump and get an RB20 pump with the small hole. It's possible the later/earlier RB20s have slightly different passageways; I have an older silvertop with "RB20" timing cover, and there is no way the 25 pump will work on my engine.
