Thank You.oldmako wrote:Yes
How long does that take? I definitely want to start doing this stuff myself. I'm tired of having to coordinate my schedule around a shop.Q451990 wrote:It depends on if it was actually drained and removed. It can be done without doing so - as was done on mine at T3. A partial drain and refill is just that, partial. It takes at least 5 or 6 drain and fill cycles to get to a 90% or so flush. I buy 6 gallons of distilled water and fill, heat up, and drain until i'm out of water... then add straight A/F for the final fill to get to approximately a 60water/40AF blend.
Heath
OAT?maxnix wrote:Real easy to get it done once with distilled water and a flush kit. Drain and refill is just so Neanerthal unless you are only adjusting concentration.!
Good time to change to OAT coolant.
