You need to do a lot more research, my friend. check out
http://www.ATPturbo.com and learn how to read compressor maps. the guys at atp turbo have really helped me learn about turbos. for 450 hp the 35 seems like overkill to me. I really am not sure. there are many variations of the 30/35/40 family of turbos, all with their ups and downs. Every engine is a big air pump, and it is all scientific. It takes certain variables, such as air flow, air temp, fuel mix, pressure, moon phase, etc, to make X amount of horsepower. the turbo is just one piece of the puzzle. SCC did a great writeup a long time ago on how to determine your turbo needs and how to interpret maps as well. Dont mean to get on a soapbox. ATP turbo has some wicked stuff, like an internally wastegated GT3071R with a V-band discharge (makes fabrication a little easier). that should get you 400-450 and spool super quick. Something else to consider is getting your stock turbo modified, ie new wheels, center section porting etc. can be done for a grand easy. might get you 400, but would definately be easiest. Good luck!!!
Modified by bmadd2402 at 7:08 PM 9/9/2006
