Quick questions
LEMHEAD16
Car: '12 Genesis Coupe
'95 QofDOOM
'56 Chevy pick up
1.) Is this nipple a good place for a vacuum source for the BOV, Greddy pressure sensor and boost gauge?
2.) Is this BOV installed corrrectly or should I flip it over? It is a DSM type BOV.
Thanks for your help. I am so close to finishing I can smell it!!!
LEMHEAD16
'95 QofDOOM
'56 Chevy pick up
bump
Titan
1) Yes, that is a great place for a vacuum source. I personally use it for my BOV & boost gauge. However you may want to put a better clamp on it. I used a fuel hose clamp, not the worm gear type.
2) I use an FD bypass valve myself, so I am not entirely familiar with the DSM one. However a bypass valve is not directional; it is either open or closed and allows air to pass through either direction. It's unlike a check valve, atleast from my understanding.
LEMHEAD16
'95 QofDOOM
'56 Chevy pick up
thank you
Structure240sx
the bov is actually wrong
crzycav86
Car: 93 Nissan 240SX KAT
Structure240sx wrote:the bov is actually wrong
werd.
You need to recirculate it.
LEMHEAD16
'95 QofDOOM
'56 Chevy pick up
i am going to recirc. it just want to know which way it goes. Thank you anthony
crzycav86
And you need to clamp the other big end where it is now..
4cefed
Car: 92 240SX Coupe
03 SRT-4
Various Dodge POSs
As to the BOV, I've never seen this one. If it's a bosch, it's probably on correctly. BOVs have a right and wrong way of mounting. Keep and eye out for a first gen eclispe/talon BOV, they are metal and put up with 25psi plus.
