quick questions guys z32 swap
allenms240
Car: 1991 Nissan 240SX
I'm getting ready to do the z32 swap on my brakes.I'll be getting all my parts rfom a 1990 NA 5spd 300zxWill the brake cables be the 2+2 style so the mounting them to the chassis will be easier?
I realize that the calipers will be 26mm aluminum, is thtat worth it? or should i try to get 30''?
And last one, i promise for now haha, will the hardware piece that mounts the 240spidle to the z32 back plate/e brake setup, be the right size from this car?
SmithSR
Car: 240sx
Your questions are all over the place.
2+2 cable. Check.
30mm calipers, pads, and rotors. Check.
Hardware piece? No check....
Bolt on brake package. Bleed system. Drive car to school/work. Done.
allenms240
so the 90 NA 5sp doesnt have the correct size bolt that mounts the spindle to the e brake assembly?
94_240sx
Car: 94_240SX
allenms240 wrote:Will the brake cables be the 2+2 style so the mounting them to the chassis will be easier?
It doesn't matter 2 seater or 2+2 cables both will work just fine.
allenms240 wrote:I realize that the calipers will be 26mm aluminum, is thtat worth it? or should i try to get 30''?
Get 30mm aluminum calipers. That's your best bet.
allenms240 wrote:And last one, i promise for now haha, will the hardware piece that mounts the 240spidle to the z32 back plate/e brake setup, be the right size from this car?
As far as I know 90 NA has correct anchor bolts. It looks like one on the right side. As you can see, it's thicker.
