HEADER.....HEADER.....Not headers. CVTC is NOT the basically the same thing as VTEC. The initial C stands for CONTINUOUSLY. In fact it's CONTINUOUSLY VARIABLE TIMING CONTROL. A VTEC contoller S-AFCII will not do anything with CVTC. Just buy a standard S-AFCII.c2dajezzo wrote:i have an 06 spec-v...ive gotten a k&n intake and am looking into headers and a full cat back exhaust...im going to eventually put an apexi air/fuel controller on it...apexi makes the S-AFC II which has a vtec controller...my question is since the spec-v has the cvcts which is basically the same concept as a vtec would the vtech controller concept of the apexi controller work with the cvcts...you would think it would but im not 100% sure...hopefully i can get some kinda answer...also if u can give me opinions on headers, lowering springs, and cat-back exhausts
