quick question
skylinedreams
Car: 90 240sx
I'm lookin for rims for my 90 240 im gonna break down and do a 5 lug conversion but this is besides the point. im lookin at rim that are 17 x 8.5 the have two offset choices theres +22 and +30 which rim would better fit my car with less headache also i plan on going with coilovers if this helps.
Exar-Kun
Car: 2005 350Z
you will most likely need to run a small spacer to clear coilovers and whatnot, depending on camber, etc.
-Chet
skylinedreams
Car: 90 240sx
so if i used the +30 I would'nt have to use spacers or anything. and will these wheels work in both the front and rear. and for the +22 could you recommend some spacers im not sure where i can get some if i decide to go that route.
