Quick question
patrickm1587
Car: 1990 240sx- SR20 swap and a turbo that's absolutely too big, spools around 4,400 and I love it!!!
I was going to replace my rear main seal and valve cover gasket, I was just searching around to see where I was going to buy these things from and I came across some part numbers. It gives the numbers for both parts I'm needing but can I get this from a nissan dealership? I know I can probably get the seal because the one on the SE-R is interchangeable, but I wasn't sure about the valve cover gasket. Here's the part number they gave for it: 13270-52F00
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
patrickm1587 wrote:I was going to replace my rear main seal and valve cover gasket, I was just searching around to see where I was going to buy these things from and I came across some part numbers. It gives the numbers for both parts I'm needing but can I get this from a nissan dealership? I know I can probably get the seal because the one on the SE-R is interchangeable, but I wasn't sure about the valve cover gasket. Here's the part number they gave for it: 13270-52F00
NICO Sponsor has the valve cover gasket on sale for $30: http://www.240sxmotoring.com/oems13srvaco.html
Rear main seal at the same place for $20: http://store.yahoo.com/yhst-11640985930 ... emase.html
patrickm1587
I mean I know where to order them from online, but I was wondering if u could get them from a Nissan dealership.
Hijacker
Car: '92 240sx Convertible
'94 F-150
I order from West Covina Nissan to get JDM specific parts. Just google up The Nismo Shop to get their sales department. The valve cover gasket is a JDM only piece, so you won't be able to find a crossover part, but the rear main is. So you can order the rear main from any US dealer, but the VC gasket will need to come from someone that can order off the JDM catalogue (ie, West Covina, Courtesy Nissan, etc)
