quick question
thor117
idk what i did but now when i take the key out of the ignition in my 09 versa h/b all of the doors don't unlock like they used to. anyone know what i did and how to reverse that?
tKowReCkLeSs
Car: 2007 Nissan Versa Hatchback SL w/ CVT, tint, DC strut Bar, and Stillen Exhaust with straight pipe :D
most likely you changed the programming of the unlock/ lock function. you can change it to a few setting depending on what you like. you had it on unlock when you turn off car and lock when you go faster then 15mph correct? i would just take it to the dealer and have them reset it for you shouldn't be a problem.
08versailles
Car: 08 Versa SL 6sp
09 Altima 2.5S cvt REAR ENDED and WRITTEN OFF
13 Charger SXT 8sp auto
Is the auto-lock/unlock available with manual transmission?
Curious cuz my SL w stick and pwr locks doesn't auto lock.
Promise Land
Car: 2011 Nissan Versa
2001 Chevy Suburban
1992 Ford Mustang
it is a function on the 09's and later. an '08 won't have it. If it turned off somehow, you can reset it by turning the ignition on and holding the lock switch down for 3-5 seconds. the turn signals should flash if I remember right. I had to read my owners manual quick tips card when I did it last time.
eeshazor
Car: 2009 Nissan Versa 1.8L Sedan, Brilliant Silver. Stillen cold-air intake with K&N air filter. Neon blue LED lights under driver & passenger feet. De-badged.
tKowReCkLeSs wrote:most likely you changed the programming of the unlock/ lock function. you can change it to a few setting depending on what you like. you had it on unlock when you turn off car and lock when you go faster then 15mph correct? i would just take it to the dealer and have them reset it for you shouldn't be a problem.
Lol.. mine locks as soon as I turn the key in the ignition
tKowReCkLeSs
ya thats the other setting. not sure if there is anyother one.
Promise Land
2001 Chevy Suburban
1992 Ford Mustang
read the owner's manual. I got a little "quick help" card with mine when I bought it.
