poshatch »
https://forums.nicoclub.com/poshatch-u145419.html
Mon Jun 21, 2010 2:00 pm
ok so when your engine is throwing a code, and you go to fix the problem
if it is fixed, then what are the sequence of events that trigger the light to go off, do you have to reset the ecu and drive it once? 4 times? (i heard that after fixing a problem the engine needs to be on and off 4 times before the ecu recognizes the changes)
or will it recognize it on its own?
