quick question
S13 240SX
Car: 93 Mazda Miata
on rb20det i'm trying to know if my iacv is bad.. I go to unplugg and it makes no change and my engine has been starting hard and running like crap for months now.
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
Tools needed:
Factory Service ManualVolt/Ohm meterCarb cleaner
The FSM walks you through the rest.
S13 240SX
Car: 93 Mazda Miata
i need a quick answer i dont have time for spending 30 minutes looking in the fsm they are hard to find stuff to begin with.
Coolwhip
Vendor
well since I'm away from my personal computer where my FSM resides I can't really help you on the specific specs on what the readings should come back as when testing it.
However, what you usualy do is unplug it (engine off) there usually 2 prongs where you test leads from to get a resistance reading in Ohms. If its within Factory spec you move on to the next step.
Blow some carb cleaner on where it attaches to the manifold (read, gasket area) if the Idle rises then you have a bad gasket.
Take off the feed hose, and blow some carb cleaner in there as well to make sure its not plugging up.
thats as much as I can help from work.
Good luck
S13 240SX
Car: 93 Mazda Miata
yeah but all i wanna know is this...
if i unplug the sensor while it is running shouldn't it cause an affect on how the engine runs?
apollas
Car: rb20 type-m
S13 240SX wrote:yeah but all i wanna know is this...
im running my rb just fine w/o the iacv due to the broken connector it came with. But Im in the process of finding a replacement for it of course. You shouldnt have any problem driving around w/o it at all.
S13 240SX
Car: 93 Mazda Miata
ok apollas but how is your ilde and start wise? like ****?
apollas
Car: rb20 type-m
Start up is ****ty ill give you that. Big difference i see with the iacv was the start up issue and that was mainly all. after about a minute of warm up w/o the iacv the idle should be fine. If your idle is a bit rough you can adjust your throttle cable by pulling the throttle back a bit to smooth out the idle.
Thats my solution for now until i get a new iacv. hope this helps
Modified by apollas at 1:57 AM 1/10/2008
