Quick Question
91ka_240
Car: Nissan 91' 240sx
i just baught a 91 240sx dual cam motor. but im kinda running short on cash to buy an sr20. and i would like to build a ka-t. im curently running on 192kmiles.. what should i really upgrade for things to handle a turbo. like i no new cams lifters pullys but theres gotta be way more to get. thanks
boznuttz
Car: MS13
First, you really need to make sure that your motor is in good condition in the first place. Focus on that first. Check out the stickies. They're chocked full of info, because it seems like someone has been telling you that it is necessary to buy a lot more stuff than you will actually need or will be using. You got a lot to learn, and this is a great place to learn it! Welcome to Nico.
P.S.You really don't need new pulleys to boost a car, lol. That's like expecting to get a new back seat to handle the extra boost.
Zippy69
Car: 1993 240sx coupe
compression test will tell you whether or not you want to boost.But like boznuttz said, read the stickies up top and you will learn all you need about boosting a 240.
WDRacing
91ka_240 wrote:i just baught a 91 240sx dual cam motor. but im kinda running short on cash to buy an sr20. and i would like to build a ka-t. im curently running on 192kmiles.. what should i really upgrade for things to handle a turbo. like i no new cams lifters pullys but theres gotta be way more to get. thanks
Use spell check, use grammar, use the correct words.
The things you listed as things you "no" need to be replaced actually do not. Like suggested, check the compression of the motor. If that's good, you'll need to change the oil pump, timing chain and tensioner, the main and rod bearings, all the gaskets as well as the water pump.
A rebuild kit is about $400 IIRC. Start there and you'll have a motor worth boosting.
Craving4Boost
Car: 91 240sx fastback
Going KA-T because you can't afford a SR is a baaaaaddddddd decision. KA-T is no shortcut to boost as they both require the willingness to pay to play. If you wanted to go SR in the first place, keep saving that money and get a SR. If for some reason you truley decided to switch to KA-T, still save money and boost your KA-T reliability. Like I said before, and many times, IMO it takes more knowledge to make a junkyard kit work than a complete kit from a brand name kit.
